I was expecting something in the $2000-$2500 range, so $3300 is a bit steeper than I would have hoped for, but I'll likely buy them anyway.
I think you'll also really like the spreader with the 100 much better than the one for the 75. I've actually seen a lot of people asking if they can use the new spreader with the 75.
What's the difference between 75/100mm spreaders?
The arms are the same as the bottom most stage/legs(CF), push-button actuation to extend/re-tract the length of the arms(indexed arms, too), as opposed to twist knobs(One of the things I hate about the spreaders on my Speed Locks, too.) Simple, easy to use center dial to adjust arm angle.
75 Spreader
100 Spreader
Good to know, thanks.
I guess if you're using a 75mm set up, hopefully the camera package is light enough so you can get away with no spreader at all.
Have used a client’s Flowtech 75 legs a handful of times, & while I still think their great, my one complaint is the locking mechanism is a bit loud, at least compared to SpeedLock legs.
