The test file 16-24_testi.wav was made to compare 24/96 (originally SACD) to 16/44.1 CD-quality is now available at http://hosted.filefront.com/Jullepoika/
This is an easy way to make a similar test AES published a few months ago where test persons could not hear the difference. Only that with this file you need no extra equipment or gear, just listen.
The size of the file is 470 MB and format is 24/96 WAV.
Download also the 16-24_testi.txt which explains how the file was made.
The basic idea is to embed random 30 second 16/44.1 sections into a 24/96 file and find out if it can be heard.
You must have a system capable of clean 24/96 WAV reproduction to utilize this file. Typical download time is several hours, so making your own test file could be faster. The .txt file explains how to do it.
