lucey
I have a couple of questions regarding the use of my NTG-2.
1. First i notice one of the XLR pins in the back of my mic is sticking out quite a bit more than the other two. It is approx 2mm more. Is this normal or damaged.
2. Is there a max cable length for running phantom power ? I have a Audio Techhnica 25' cable and i cannot seem to use phantom power with it. I use a AA and all is good. Also i use phantom with my 1.5' no problems. I cannot seem to find any info on this.
3. Can someone point me in the right direction for obtaining proper audio levels while shooting. I seem to be a little on the quiet side once imported into FCP. Do most people go for a higher Db on the camera and reduce in post or vice versa. I have been using one channel a little lower than the other for possible clipping issues. Any good advice ?
