Hi,
Im am currently looking into getting a better mic than I have now, I use an external system to record sound, a minidisc.
I am looking at the RODE NTG-2 because when I am on location I dont want to be messing around with Phatom Power its just easier to have a battery in there, is there any difference between using the battery over the phantom
So this is my set up. Im going to use the RODE SM-3 shock mount attached to the boom pole, using a blanced XLR lead (2M) to an 6.5 jack then convert that to 3.5 so it can plug into the minidisc, is this ok?
So I would like to use the mic as far away from the subject as possible and still pick up excelent audio I see its Supercardioid so it has a fairly nice pattern, looks better than an shotgun mic.
We will be filming in and out, so will the deadcat/windshield reduce the strength of the mic because it is like covering the mic up so it wont be as loud I suppose. We will be also be doing vox popping so we dont want to put an mic in peoples faces too much
What you think?
What you think?
