Here's a casual demo I did.
Cheers.
Do you know of a good article about which mics should be used indoors and outdoors for video which you point people to? I'm in the market for a mic or two for filmmaking.
-Andrew
Indirect sound hits a mic with a slight delay and is phase shifted with respect to the direct component. When you use an interference tube based mic, the direct wave component is mixed with the indirect wave in the tube and the resulting mix of the phase shifted components gives rise to comb-filtering effects where some frequencies are emphasized and others are cancelled. I liken the resulting sound to voices in the bottom of a well or in a metal culvert, the sound taking on a hollow, ringing quality. So interference tube mics are often used outdoors while hypercardioids, which get their directivity from a different physical prinicple altogether and don't have any interference tube mixing, are used where high levels of indirect sound are present.
