i have a question about the new rode lavalier. I'm really looking to buy it, but i have question.
I plan to buy a tascam dr100 and plug a rode lavalier with the XLR micon.
I thought of buying the sony pcm10 instead, since its a smaller unit,
1) can i plug the rode lavalier with a micon 2 directly into the line in (3.55mm) of the sony pcm10 ?
(on the specs of the sony, it says it gives phantom power, but not 48v. DOes the sony pcm10 offers enough phantom power for using the rode lavalier ?
2) will the sound of the XLR will be better in the tascam than the sound i can have with the sony pcm10 in the 3.55mm) ?
i found some specs for the sony PCM10 :
Input/Output
• Microphone jack (minijack, stereo), input for
plug in power
– Input impedance: 22 kΩ
– Minimum input level: 0.9 mV
– Rated input level: 2.5 mV
• LINE IN jack (minijack, stereo)
– Minimum input level: 500 mV
– Rated input level: 2 V
since the rode lavalier is designed for a 3.5mm stereo minijack, with a power supply of 1V minimum, will the sony pcm10 will work ?
(my 2nd question would be : the fact that its a 1/8 connector instead of an xlr, will this make a big difference ?
Thanks in advance
Have a good day,
Julien
Input/Output
plug in power
Thanks in advance
Have a good day,
Julien
