Hi guys,
Ive been putting together my rig for my 60d. The mattebox, cage and ff are mounted on 15mm rails, all standard stuff. Now my problem is, when my 60d is in the cage, it's not high enough for the lens to be center in the mattebox, the lens is towards the bottom of the mattebox, even when the mattebox is lowered to it's lowest point. The cage was designed for the 7d and the 5d, I don't know if that would make much of a difference, but I need something that can go into the cage to mount my camera on, as I wasn't planning on needing this, I really would hope there is something cheap out there that can do the job, I've seen some arri baseplate risers, way out of my range.
Ive been looking at battery grips, but I know for a fact that when a battery grip is used with a 5d in this cage, it won't fit...so I'm worried that it might not fit in the cage with a 60d either, but I'm not sure.
So would anyone know of anything that I could mount the camera on in the cage to solve this? It was just need a 1/4" input on the bottom for the cage and a 1/4" screw on the top to mount the camera on, if there's nothing I'll just have to do a diy.
