I am having a problem using the RGB Color Corrector in CS6. When this effect is applied to a clip the Program Monitor window does not update when changed are made. When using this effect I also periodically experience a message that states that the media is missing, which it is not. I am using CS6 v6.0.5 on a 64 bit Windows 7 machine.
This problem is documented on the web as a bug which, apparently, Adobe has chosen not to fix. However, on other forums it is suggested that a workaround is to replace the effect AEFilterColorRGBCorrector.aex with the version 6.0.1. Unfortunately, all the links to download this file have expired.
Does anyone have a current link to download the 6.0.1 version of AEFilterColorRGBCorrector.aex or, perhaps, another solution.
Any other bugs I should be aware of? :-(
I apologize if this has been posted before (I would be surprised if it has not been) but this forum would not let me search for such a long name as AEFilterColorRGBCorrector.aex.
Thanks,
Dan
Thanks,
Dan
