Larry Rutledge
Fest Master
Canon 7D vs. Panasonic GH1
Is one of these "the new DVX"
by Barry Green
Click here to read the full article
by Barry Green
That setup can deliver gorgeous results, so long as you watch out for things that cause aliasing artifacts (certain patterns or fabrics, or thin-rimmed glasses). And you might want to invest in an inexpensive prime lens, a 50mm/1.4 should be easily available for under $50 and would make for a nice portrait look. The stock lens is plenty sharp, but at f/4 it doesn't really provide for that hyper-shallow depth of field look that makes certain interview shots so attractive.
Because the construction quality and the optical quality are the most like true cinema lenses, at the most affordable price. The ZF lenses are the exact same glass that's used in the Zeiss Compact Primes PL-mount lens set. I actually considered getting a set of CP's, because I'm tired of dealing with the goofiness of still-camera lenses that were never designed for cinema work. But the $27,000 price tag for a set of four was quite off-putting, and the PL mount would make them unable to be used on something like a Canon or Nikon body.Thanks for another very informative article, Barry.
Just curious why you chose Zeiss lenses over Nikon or Canon.
The ZFs, on the other hand, are 1/4 the price and have the identical same optical characteristics as the Compact Primes. The focus rings are exquisite, designed more for cinema use than the typical short-throw SLR focus ring. My 85mm lens has a 270-degree focus travel, it's just perfect. The Nikon mount makes them adaptable to pretty much any camera out there, whether Nikon, Canon, Panasonic, or Red. And after the Duclos modification, the iris ring becomes comparable to a cinema lens iris ring as well, and with standard gearing and standardized fronts, they pretty much overcome all the hassles of still lenses and deliver the visual quality of cinema primes. The only major annoyance left is that they focus backwards, because Nikon lenses focus backwards, but a follow focus with reverse gear will fix that.
You can probably find a hundred reviews about the ZF lenses on the web. One of them (Ken Rockwell's) is negative. Every other review I found is gushing.
Rockwell's review is hostile from the opening sentence. Using phrases such as "the cheap FM-10" and "manual focus went obsolete 20 years ago" are just hostile and fuddy. Reading it, it sounded like he had a chip on his shoulder from the beginning. Now, I don't know or care what he prefers, but what I wanted was excellent performance, beautiful imagery, and the slickest, sweetest manual focus I could get, and the ZF has it. Oh, and it also happens to have gorgeous build quality overall, and stellar performance, and really has nothing in common with a "cheap FM-10".
I was initially bothered by Ken Rockwell's review, and frankly it made me hold off on buying any of these lenses for quite a while. But after something like a dozen other, screamingly praising reviews everywhere else, I took the gamble. I got the 50mm because it was the cheapest, and ... it's the cheapest. It's my least favorite. If anyone was going to complain about any of the ZFs, it would be this one. But even so, if you stop it down a couple of stops, it begins to become wonderful. So I no longer put any stock in that review. Besides, what he wanted is not what I want -- he wanted a lens he could "focus with one finger" and that had autofocus. I wanted a lens that delivered cinema-worthy results, for a lot less than the Compact Primes.
Secondly, the ZFs are not the same lenses as the Contax ones were. The optical design is different, and reviews have shown the ZFs to outperform the older Contax designs.
Third, pick one up and hold it -- you'll be able to tell the difference between a ZF and any other SLR lens. It does exactly what I want -- gorgeous image rendering, beautiful solid delicious construction quality, and heavenly manual focus with massively long focus throw.
Fourth, lenses are a matter of preference, some like and prefer the warm/soft Cooke look, others prefer the Leica look, I happen to crave the Zeiss look of super-sharp and ultra-contrasty.
Fifth, I repeat -- Zeiss now sells the same glass to the cinema world as the Compact Primes, where each lens is rehoused in a PL housing with proper cinema focus and throw, witness marks for the focus and iris, and standardized fronts. Those lenses cost upwards of $4,000 each, and a complete set of seven costs over $27,000. The glass is the exact same in the ZFs. For $250 apiece you can get these lenses modified to perform much more like cinema lenses, so for 1/3 the price you're getting cinema-ized versions that perform like a professional cinema lens set...
In any case, any of these SLR lenses are massive overkill for SLR video use. If you want to buy a lens for shooting HDSLR video, a cheap 50mm will be just as sharp as a ZF or other premium stills lens.
As a professional video camera to replace an HPX170 or EX1, which one would I use? Neither. No possible way. They aren't ready for that. Way too limiting, and the potential image artifacting that happens because of the extreme aliasing they both use, means that for me, as my own choice, I would not risk my reputation or my paycheck by using one of these instead of a professional video camera.
