David Jimerson said:Depends. If you've already pressed the blacks (master pedestal of -5 or lower), then you probably aren't getting the shadow detail back. You can brighten it, to be sure, but the detail isn't there to be had.
But if you've gone the other way -- MP of +2 or higher, say -- then you can use the Offset in the Color Corrector, or press down the RGB Color Curve, or a couple of other ways, and bring things down.
