Hello,
I read through many threads here, hoping to get an answer on this particular question, but since this was not the case I try to ask.
Source of my footage is Panasonic HMC-151, which delivers AVCHD files at 21Mbit/s mean and 24Mbit/s max bitrate using 720p50 mode.
I'm editing on Premiere CS5.5 and exporting the material to H.264/m2t files.
I made my own export preset and selected 24Mbit/s (VBR) as the maximum bitrate to match the max. camera bitrate. Output looks quite good.
If I look at the premiere or mainconcept encoder presets, they typically have 8...11 Mbit/s as the default export
bitrate for H.264/bluray, so I wonder if I'm wasting file size by using a too high output bitrate ???
I did some tests with 8Mbit/s instead of 24 Mbit/s and if I compare the results in full resolution there is almost no or no difference at all visible,
but I know that it also depends highly on the source material, kind of scenes, ...
Therefore the question comes down to that point:
Does it make sense to have the export bitrate as high as the camera bitrate or does this only
waste disk space ?
Thanks,
Markus
waste disk space ?
Thanks,
Markus
