I'm wanting to get some equipment for timecode-based double-system sound recording, and at the moment I'm thinking about pairing up a Denecke timecode slate or an iPad running MovieSlate with either a timecode-capable file-based audio recorder (like the Zaxcom ZFR100) or a timecode-capable portable DAT recorder (like the Fostex PD-4). Before making a decision, though, I thought I'd see if someone could help explain the way these systems capture/store the timecode data, and how it translates to non-linear editing.
If I chose the DAT option, I'd need to manually ingest the audio tracks, along with the timecode audio track. If I went with a file-based recorder, my understanding is that the timecode is embedded into the metadata of .bwf files. That said, it seems that going the .bwf file route would be the easier solution, but I'm curious if most Mac-based editors like FCP, or maybe even some basic, open source editors, can easily import .bwf files and translate the timecode metadata.
On the other hand, if I wanted to go the DAT route and had to manually ingest the audio and TC track, are any editors set up to decode / resolve a analog TC audio track and apply the resulting TC to the audio clip? It seems like this approach would easier said than done, and that I'd probalby need to use some third party plug-in or application to resolve the timecode for a non-linear editor.
Finally, for .bsw files that contain timecode data, does the timecode encapsulated in the metadata indicate only the precise frame at which the audio clip started recording (in other words, only a single timecode value), or does TC data exist for the entire duration of the clip? When it comes to applying this to a non-linear editor, I'm curious if the editor just looks at the timecode value recorded at the very beginning of the clip then calculates the TC for the remainder of the clip, or if TC data actually exists for each frame/sample of the entire audio clip.
Thanks to anyone who might be able to offer some advice!
