I am going to download their free version and start learning it. Got to comfortable with Premiere Pro. Resolve benchmarks seems to show twice the speed in rendering, with many seem to be very happy working with Resolve. Soon BM will buy a photography software and integrate it with resolve. Adobe, you better watch out.
When you see the way it works, you might change your mind. It's extremely well implemented... and I suspect that you're underestimating the Fusion user base.
Yes, there was a free version, but like its free Resolve counterpart its feature set was limited. But unless I'm mistaken, Resolve Studio 15 contains the full version of Fusion, essentially for free.I just find it odd that Fusion was there and free and now all of a sudden people are excited about it like they never had access to it before.
My point was that the new version of Resolve will have the full version of Fusion effectively for free. At least that may happen eventually. Buried in the press release, which I didn't see until today, is the following: "Adding Fusion to DaVinci Resolve has been a massive project that will be completed over the next 12-18 months." The separate, standalone versions of Fusion 9 will continue to be available for those who need them. As to the limits of the free Resolve 15's Fusion component once it's fully integrated, who knows what BMD will do? For example, by then, the UHD output limitation may have given way to "8K" UHD (7,680 x 4,320). The collaboration features, however, will likely always be a premium.It was not that limited at all. Not any more limited than the free version of Resolve. Fusion could do 2D and 3D comps, load 3D models and use almost all fo the nodes including the Delta Keyer and only some of the advanced stuff like noise reduction was deactivated. In fact Fusion may now be even more limited by the free version. For example Fusion 9 didn't have a resolution limit. I could load DCI 4k or 4.6k content no problem. The free version of Resolve 15 however is limited to UHD or lower resolution. Since you can't load in any content larger that means the Fusion built in is now also limited to UHD.
There may be other new limitations I haven't run into yet but basically now if the free version has a limit then so will Fusion. Another example is loading 10bit material from the GH5. Resolve 14 could load it with the paid version but not the free version. Fusion on the other hand could make use of ffmpeg as an alternative loader to load the 10bit files from the GH5. Unless Resolve 15 suddenly supports the GH5 for free that means Fusion will now also have this limitation.
Going from FCP7 to resolve was much easier for me than going from 7 to X. Just downloaded 15, and for the free version they are still crippling h.264 playback. 4k h.264 GH4 files are choppy during playback, while FCPX on my system handles them just great. You have to pay for the studio version to get better h.264 playback apparently.
I've installed the Beta version of Resolve 15 on 2 different 2012 12 core mac pro's and each time i click on the Fusion tab Resolve crashes.
is this just the nature of a Beta release?
