Helooka Likeaman
Okay, I'm at it again. I would like to find a dirt cheap alternative to rod systems that cost $150.00 plus. I'm not sure if this is possible but I am researching parts right now.
Once again to keep costs within reach of everyone I would like to purchase the components at readily available home improvement and retail chain stores.
Unfortunately the rods I am coming across thus far are not in mm's but inches so the rods I have found are 1/2" in diameter which is 12.7mm, 2.3mm too small.
My question is: Will 2.3mm per rod make that much difference? I was thinking I could make up whatever discrepancy there is by adding a mm or two to the 60mm space between the rods. I realize that pre-milled accessories such as follow focuses and matte boxes will be a little loose on the smaller rods so I was thinking about possibly contact cementing something like velvet over the rods - this would aid in thickening up the rods and smooth out operation/movement. Or maybe not - still thinking this through.
I realize that there are rods available, good rods, from a few sources but they run between $15.00 and $20.00 per rod. This kind of defeats my purpose of keeping costs low especially when I can get one 1/2" x 3' steel hollow tube for $6.88 and cut it into two really nice long rods.
Any input will be appreciated. If you have a cheaper source for 15mm rods by all means let me know. If you think I'm crazy, let me know that too.
:dankk2: in advance.
