I recently, and for the first time ever, used the Replace With After Effects Composition option in Premiere pro to do some simple masking on a dance. I created the mask, animated it, and fixed the problem that I originally set out to fix. However, it seams that after effects is doing something weird to the bit of video that I used and sending this oddity back to premiere pro when I both preview play it and export it. The video is all DV and after effects correctly interrupted the footage from what I can tell (lower field first, correct pixel aspect ratio, correct resolution) but the interlacing lines are gone and it looks kind of blurry. It looks to me like it's performing some type of field blending or de-interlacing, but I'm still very amateur at all this and am not 100% confident in my analysis of what's happening. I've included a screen shot from the last frame of the after effects composition, and the first frame from the premiere pro sequence. The frames are right beside each other chronologically.
Screenies:
After effects composition screenshot
Adobe premiere sequence screenshot
I'd like to apologize if this should have been in the premiere pro section; I had to think this one over a few times and I ended up choosing the after effects section because I think that after effects is the problem. I just want it to be known that if this happens to have been the incorrect section, it was due simply to a mistake and that I really did consider which one I should post in
Thanks much
rogar-BigGrin(DBG)
Screenies:
Thanks much
