Timzilla Member Dec 31, 2005 #1 Any ideas where a good place to go in Vancouver would be to service my G2s? I have some strange popping and peaking going on, and rather than messing with them I'd rather take it to the pros... Thanks! Tim
M matthewd5 Veteran Dec 31, 2005 #2 did you try going into the menu and doing a reset?? that shouldn't hurt anything at all and it is free. of course also check the batteries and the connections. matthew
Timzilla Member Jan 1, 2006 #3 yup- tried that. I can't tell if it's the connections as there doesn't seem to be anything loose... any other ideas? Thanks- Tim
Jarred Land President/Founder Staff member Jan 1, 2006 #4 goto canadian tire or radioshack and buy some electrical connection cleaner.. spray that stuff. Also check your cables
M matthewd5 Veteran Jan 2, 2006 #5 i would try to find someone who has the same gear or who has a lot of experience and ask them to look over the connections for you. i personally wouldn't try spraying anything on it but i don't know that much about electronics as far as what is ok to do at the pc board level. matthew
Jarred Land President/Founder Staff member Jan 2, 2006 #6 lol i guess i wasnt very clear.. by spraying i was refering to the contacts, where the plugs are.. not on the actual PCB board. if i wasnt about to move and had everyting packed i woulda invited you over to help troubleshoot. ( i have a couple G2's)
