Repair Permissions...
Is repair permissions the same thing as trashing preferences? I am right in the middle of a project, is it ok to do either/or of these If I need to?
Re: Repair Permissions...
No -- Yes.
Repair permissions is a function of Disk Utility. Trashing preferences is something you have to do manually.
Either are fine to do in the middle of a project, BUT -- you will loose your window set-ups and any favorites you might have in effects or transitions.
Repair Permissions: Applications/Utilities/Disk Utility. Find your boot drive click it and select repair permissions. Do it twice.
Trash preferences:
http://docs.info.apple.com/article.html?artnum=93385
Good luck,
CaptM
I do have an effect that I have saved that took me 3 hours to complete. How can I save it somewhere else if it is going to delete my favorites?
You could try right clicking it and opeining in editor. Save the file as a text file and reimport when done.
Unless this is a non FCP plugin -- you might run into problems there.
CaptM
