I was having serious difficulty rendering a project back into .MOV format so after some research I read that Main Concept AVC format is probably the best setting to use when rendering with Vegas (although some of you may disagree).
Anyhow, I rendered my project using MainConcept and it rendered fine into an mp4 file. However, when I watch the playback on Quicktime, I noticed that there is like a line flickering when there is a lot of movement in the picture. For example, if a subject is sitting still in a chair, the footage is fine, but when they stand up or make a large movement, a line flicker appears across the screen where the movement is. I am assuming that I am doing something wrong somewhere in the render settings. The footage was shot on a Panasonic GH1 in .MOV format (1280x720) at 30fps. Playback on the timeline in Vegas itself is fine but when it's when I render it out onto my hard drive and watch the playback, that when I see this flickering effect during movement in the picture.
Just to clarify, my plan is to render this footage out and then re-import it back into a new project in Vegas so I can cut and edit clips from it to make a trailer for the main project.
Am I using the wrong render settings for this purpose? Can anyone help me out here?
