I shot in 24p advanced, edited, and want to create a dvd with native 24p using DVDA. My understanding from reading the Sony whitepaper is that the dvd player will detect flags on the disk when it is burned with native 24p and then insert 2-3 pulldown for NTSC viewing. Is this correct so far?
Anyway, when I go to render my 24p video in Vegas, I select the default "dvd architect 24p NTSC video stream" (as noted in Sony whitepaper), but in the custom template settings (in rendering setup) on the "video" tab I notice a pulldown menu where I can select a frame rate of "23.976 + 2-3 pulldown" or "23.976" (as well as several others). Can someone explain the difference between these two? I would guess that the former setting would insert the 2-3 pulldown during rendering and the latter would result in native 24p rendering (whereby the dvd player would then insert the pulldown), but can anyone confirm this for sure?
Is there any way to determine with certainty once a dvd is burned that it contains native 24p instead of 24p with 2-3 pulldown?
Thanks much!! This site has been fantastic to a newcome like myself.
