I have specs I need to follow for rendering a feature length movie that will be used for streaming, but I'm rather lost and can't seem to find the right information on how to follow these specs.
I have Sony Vegas 11 & 12, so I can use either one for this. The info I'm listing about what I'm trying to do will be in terms of Vegas 12.
The footage I'm trying to render was shot on a DVX100B 24fps Squeeze
Here is the spec information I'm trying to follow:
Here's where I'm running into problems and there are many:
First choosing the right CODEC:
I'm thinking I need to render as MP4 to get this H.264 - There are 2 options for MP4 Rendering on Vegas 12. One is Sony AVC/MVC and the other is MainConceptAVC/AAC.
The Sony AVC/MVC has a lot of options that don't make sense to me. So I'm assuming MainConcept AVC/AAC is where I want to be.
Inside this codec I am guessing I should choose one of the internet options and the highest quality option appears to be Internet 480p widescreen, so that's what I've been choosing.
IF I'm in the right codec, this is the issue I'm having with following the specs.
Codec/Compression format: H.264 - - - I think I'm in the right spot ????
Multipass: On - - - I have no idea what this means and see no options for a multi pass at all.
Frame rate: Current
This should be either 24, 25 or 30 fps - whatever you edited in. - - - When I click on CUSTOMIZE TEMPLATE the Frame Rate I have has several options. There is one option of 23.976000 (IVTC FILM) and 24 (FILM) and I'm assuming I should choose 23.976000. Does that sound right?
Video data rate: 2500kbps - - - I see no option for for Video Data Rate at all. The closes I see to that language is variable Bit Rate, but it doesn't have an option close to 2500kbps that I can see.
Resolution: for PAL videos 1024x576 orfor NTSC videos 854x480
The pixels should be square or 1:1 - - - There is an option for Multimedia wide (854x480) so that's easy enough, but for Pixels, I don't see any options for 1:1 - I have an option for Pixel Aspect Ratio, but my options are 1.0000 or 1.3333 - Is 1.0000 equal to their spec of 1:1 ?
Interlacing: Video should be de-interlaced or progressive
If the source video is interlaced, be sure to select the "Deinterlace video" option, but if the source is progressive or already de-interlaced you don't need to do this again. It's important to select the right de-interlacing option or your video will look bad on the web. - - - I'm pretty sure DVX100B footage is progressive, so I don't have to do anything here correct? If so, I don't see any options for it anyhow.
Sound: AAC Codec, Stereo, 48khz, 320kbps - - - When I click the Audio tab at the button, it shows the sample rate(Hz) at 48,000so that should be good. I don't see an option to adjust to 320kbps. In the format information section it is mentioning audio at 128 Kbps. Is there anyway to up it to the request 320kbps?
I've tried rendering using all the above information and the MP4 render comes out in horrible quality.
Any information anyone can give is much appreciated. I'm very lost.
- Codec/Compression format: H.264
- Multipass: On
- Frame rate: Current
This should be either 24, 25 or 30 fps - whatever you edited in. - Video data rate: 2500kbps
- Resolution: for PAL videos 1024x576 orfor NTSC videos 854x480
The pixels should be square or 1:1. - Interlacing: Video should be de-interlaced or progressive
If the source video is interlaced, be sure to select the "Deinterlace video" option, but if the source is progressive or already de-interlaced you don't need to do this again. It's important to select the right de-interlacing option or your video will look bad on the web. - Sound: AAC Codec, Stereo, 48khz, 320kbps
Frame rate: Current
