I have some specs I'm supposed to follow for rendering a feature length film of about 97 minutes. The footage was shot on a DVX100B 24fps. I have Vegas Pro 11 with Raylight & Vegas Pro 12.
The specs are as follows:
NTSC:
Frame Rate: 23.98fps or 29.97 (Native Frame Rate of Original Source
Frame Size: 720x480 or 720x480 or 720x486
Bit Rate: 50 mbits
QUICKTIME:
Codec: 8 bit or 10 Bit Uncompressed or Native Video Codec (ProRes422 (HQ), DV, DVC Pro)
Pixel Aspect Ratio: 16:9 (853x480) or 4:3 (640x480)* *Not to be confused with Frame Size*
Audio:
Stereo: LPCM in either Big or Liole Endian, 16‐bit or 24‐bit, at least 48kHz
Surround: Required channels: L, R, C, LFE, Ls, Rs, LtRt
I'm just having a difficult time finding the corresponding information when going through the RENDER AS process.
The specs they gave me are for a Quick Time Codec -
When I click RENDER AS, I choose QUICKTIME 7 (*.mov)
From there I am given several options, I'm assuming 3 Mbps Video is the right choice
From there I click Custom Template
From here:
For the NTSC Specs -
I see a FRAME RATE option with 23.976 (I'm assuming that's what I should choose)
I see a FRAME SIZE option, with the choices of 720x480 & 720x486
I see nothing here for BIT RATE
For the Quick Time Specs -
I see nothing to choose for 8 bit or 10 Bit Uncompressed or Native Video Codec (ProRes422 (HQ), DV, DVC Pro)
The Pixel Aspect Ratio listed gives options of 1.000 - 0.909 - 1.212 - 1.093 - 1.457 - Are any of these to be chosen to correspond with a 16:9 Pixel Aspect Ratio?
Audio:
I don't see much correlation through their spec requirements with the options given when clicking the Audio tab.
The movie on the Vegas Timeline is Surround.
I see on the Audio Format there is an option of 16-bit Big Endian and a sample rate of 48,000 (The highest listed)
so under the Stereo spec, it seems like that would work.
However since it's Surround on the timeline I don't see anything listing the required channels they ask for which are: L, R, C, LFE, Ls, Rs, LtRt
On here for the channels there is an option for Stereo and Channels 1 thru 32. Nothing else is listed.
Is anyone able to educate me on this a bit. I'm pretty lost.
Thanks!
NTSC:
Bit Rate: 50 mbits
QUICKTIME:
Audio:
From here:
Audio:
Thanks!
