Rendering causing MASSIVE degradation?
markinhifi
In the final film i'll ever cut in FCP 7, i've run into a pretty huge issue at the finish line: major image degradation upon rendering a clip. Take a look.
No grading. Plain ole h.264 file.
http://rovingtypistfilm.com/misc/sc3.jpg
After grading is applied with Magic Bullet Looks (unrendered)
http://rovingtypistfilm.com/misc/sc2.jpg
After grading is applied with Magic Bullet Looks and clip is rendered
http://rovingtypistfilm.com/misc/sc1.jpg
See how that quality went way downhill after it was rendered? What's happening there? Am I doing something wrong? Can this be prevented in any way?
Might have been your final output settings. Unless you have been using the same settings for your past projects then this happened all of a sudden.
Sorry, not sure if I understand the questions exactly. I'm not exporting this film. I'm talking about simply just rendering the clip in the timeline after applying anything to it. The files are h.264 from a Canon 7D. (I read that could cause a problem, so I tried a ProRes clip and get the same results). Here are all of my sequence settings, if that provides any insight at all. http://rovingtypistfilm.com/misc/sequence.jpg
This may not be degradation, it may just be taxing your RAM to playback at full quality. Try exporting the clip as a self-contained movie to verify that degradation has actually occurred.
Hi folks! Update! User bscheerer sent me a message with the solution. In Sequence settings > general > quicktime settings, I had the render settings set to h.264. Switching that to ProRes solved the issue! Thanks to him, as well as everyone else in this thread. Cheers!
