Render?
Sherman
Short (2:14)green screen project.
HD 720p-30p.
Need to render and retain alpha channel for editor at other end who is cutting in FCP.
But rendering to .MOV (as requested) results in a 13GB file?!
Seems impossible.
What other settings would you suggest to keep the file small, quality high and retain the alpha channel?
Have to overnight this tomorrow!
Thanks,
Dan
you don't have many options
high quality and small filesize are opposites, you can't have both
for lossless formats in mov, you have animation codec or png (both with alpha) ; png will give you the better lossless compression .
I think animation has a quality slider, so you can reduce the filesize & quality . It also has to be set to millions of colors ++ for alpha channel, (RGB+A) , otherwise it will render RGB only. I've never used it at lower quality, so I don't know if it works
