Render to Mpeg2 ?
JohnT
Just finished my first wedding edit and it looks pretty good.
I have started to render the project to a Mpeg2 DVDA 24p NTSC Video stream. I understand after this is done I will need to render the audio also? Any quick help on this would be appreciated.
JRT
Re: Render to Mpeg2 ?
At default settings, yes, you'll have to render the audio as well. Name it the same as your video stream.
I saw the default templete but Iam rendering it 24p DVDA video stream as the manaul said. I hope this is right.
OK David,
The video rendered and played in the media player without the audio, so I need to now render with the same templete, but this time highlight the AC3 audio to render the audio. Correct?
Hopefully, you still have your loop region selected. Render As and then choose AC-3 format.
This is what I did.
1. Rendered the entire timeline in 24p. 2.3.3.2 pulldown.
Footage was shot in 24pa.
2.Highlighted the entire timeline and using the main concept Mpeg 2 encoder,Saved as DVD 24p video stream NTSC.
3. Now I went back and save the same file, but this time I save it as a AC3 audio file.
Just checked and it has completed also.
Hey David,
Thanks for your help. Now to the burner with it.
