indybones
Hi Guys..
Could do with some help on this confusing one please.
Footage captured on HVX-200 (25 progressive) format,
Rate 25fps
Size 1140 x 1080
DVC PRO HD 1080i50
Pixel aspect ratio HD (1440 x 1080)
Field dominance (odd)
I have copied these settings into the sequence settings.
The question is about split screens, I'll try and be as succinct as possible.
In the past when I have done a four screen split screen using SD footage I have shrunk the size of each clip in basic motion (to about 45), then moved them into the four corners of the viewer creating a grid of four.
With the render lines in GREEN appearing, meaning that I can still play the film but it's preview. However when I do exactly the same thing with the HD footage (see above) RED render lines appear which means I cannot preview it. Four screen image below.
I'm rather confused because I'm doing exactly the same thing as I did with SD footage in basic motion than I am with this HD footage, but these RED render lines makes it impossible to work with because each time I want to see how the cuts work I have a 2 hour render.
Any thoughts and help would be very much appreciated.
Thank you for your time and help.
Indy
Rate 25fps
Size 1140 x 1080
DVC PRO HD 1080i50
Indy
