Render Crashes ??
PhotoJim
I updated to Vegas Pro 8 a short time ago. I just finished shooting a training video for a client (2.5 hours edited length). That is divided into 3 separate segments about 48 to 50 minutes for each segment. Each segment is rendered separately. There is a primary video track where I laid down the instructor speaking before a group.. very simple, straight forward shot. The video track immediately above contains still shots (slides, saved in Photoshop as ".PNG" files).
A third video track contains only titles and superimposed type as "text generated media" created in Pro 8. There is one audio track.
My computer has a Intel Pentium 4 CPU @ 3.2oGHz chip with 3 GB of RAM. The video card is a NVIDIA GeForce FX 5200 that feeds 2 CRT monitors. I downloaded my primary video to a 500GB USB external hard drive, edited the footage and saved the first, finished 48 minute segment to an internal hard drive (D) INCLUDING the check box "Save Media with FIle".
I started to render an MPG2 file (for DVD Archietect) but the render time was amazingly SLOW. Projected completion time was over 18 hours. I let it run overnight and it eventually crashed after 7 hours with less than 5% rendered.
I tried to render it as an AVI file and had the same results. I then tried to render it as a QUicktime 7 Movie.. it seemed to start rendering faster, but the program crashed after 3-4 minutes...
Windows has not crashed... Vegas crashes (error message and "has to stop").
The Operating System is XP PRO - SP3. I had been only been running SP2 until 2 weeks ago. I upgraded my ADOBE software to CS4 and the upgrades would NOT install without first downloading and installing SP3.
This is very frustrating! Render times are horrendous... and Vegas crashes after a few hours at less than 4-5% completion. I don't know if the Adobe Upgrades (PhotoShop, Dreamweacer, Premier Pro, Flash, etc,) are interfering with Vegas??? OR if SP3 is causing the problem???? or if I am the problem because I don't have Vegas Preferences set correctly???? or if the still shots being formatted as ".PNG" are the problem???? :crybaby::crybaby::crybaby:
Sorry this is so long... but I wanted to include everything I am doing so it might trigger a solution from someone.
Thanks!!! :crybaby:
Photo Jim
What kind of video is it? What kind of FX do you have on the video?
How big are the slides? Did you zoom in on that at all?
I do have the say that your hardware is 5-6 years behind. Shouldn't necessarily be a problem, but there could be some kind of bottleneck with it, and it could make a difference with some of the newer types of video footage out there.
