Removing plugins from multiple clips on timeline
greeches
Any way to remove multiple plugins from a series of clips on a timeline? I have magic bulleted into a project and want to change all of the Magic Bullets, but must I change each individual clip's plugins?
Copy and paste will only work if ALL other FX are the same. Otherwise you will loose the other FX you might have added some of the events.
Ultimate S2 allows you to do that you want. That’s one difference between our FX chains and Vegas’, we let you remove ours. What you could do is download the Ultimate S2 trial and install it (it will work for 15 days), on the Video FX tab, set up an FX preset with just Magic Bullet in it. Then tell US2 to remove that from all selected events. One button push and you’re done. Then change the Magic Bullet preset in that FX and reapply it to all selected events with one more button push.
Then check out some of the great ReelPak Film Looks that David has created for us, that plug into Ultimate S2. They render a lot faster than Magic Bullet and (IMHO) look just as good.
~jr
Tried that to remove effects. Didn't work. :( I could paste effects to multiple events, but couldn't paste "no effects".
Bummer. What did I do wrong?
Dan
Paste Event Attributes ADDS - not remove. To remove all effects from all events, the quickest way is to use a script.
