Removing H.264 Compression artifacts from flat color areas
eco_bach
Hi
I have some shots with blue skies I am trying to rescue. The problem is the excessive amount of 'blockiness' that becomes apparent the moment I start doing any color correction. I've tried extreme amounts of remove grain in After Effects which removes about 50% of the problem. Outside of blurring, does anyone know of any 'tricks' to help eliminate these compression artifacts?
