Removing camera 35 mm noise
I'm working on a short film, in the sound post-production, and it was filmed in 35 mm with the arri bL (i don't know the further reference) and it is indeed a really noisy camera.
I'm working with pro tools and with izotope plugins, but, i think tha the camera noise is in almost every frequencies.
Do you know anything to help me eliminate it?
Thank you all.
Try a noise-gate to remove or lower the noise between lines, then mask it with other sounds, (depending on your location) City street sounds, birds, wind... Also, you can use a tight notch eq, boost it all the way up and move the freq around until you find the strongest part of the 35mm noise, then lower that as much as you can.
Bummer you couldn't blimp the cassette when shooting... something to consider for your next production. I'm all for a tight notch filter swept to find the main frequency... then you can notch out the harmonics of that frequency.
