Remove one effect from every clip in time line
maltess2
Hello, I applied noise reduction "neat video" to most clips on a project in the timeline. Now I would like to remove that effect, It is possible to do all at once? otherwise I have to go clip by clip removing this. The problem is every has other effects as well that I dont want to remove.
cheers
You can Remove Effects from a group of clips at once by selecting and right clicking, but it doesn't allow effect selection beyond the very broad Video effects or Audio effects.
I'm not sure any NLE would let you do that with such specificity. There are those which would let you remove it from one clip, copy the FX on that clip, and then paste the FX attributes to the other clips, which would make the FX on those other clips identical, but that wouldn't work for you if don't want identical FX on all clips. It would, however, get rid of Neat Video from all.
With Paste Attributes fixed effects get replaced, all other FX are added.
With Remove Effects if video effects is checked all non fixed effects get removed, there is no choice.
So if you want just one effect removed you have to do that for each and every clip manually.
