One other feature that I am thinking I might add at this stage is a pause button. If you set your focal distance and you do not want to loose it (other than drawing a line on the marking disk) you can press the pause button. This will lock the servo at the current position and turning the knob wont do anything. When you press the button again it will revert back to normal mode and it will jump to wherever the knob is at that moment.
Are these updated and changes a good thing?
If I understand it correctly this 'pause' button could be used as a poor man's preset focus position.
Don't forget, I'm on your reservation list #4.Well at the moment, not very long. We are about to develop a little gadget that sits at the end of the cable so we can encode the signal so it wont get lost....
The default speed at which the knob turns back might not be good enough for all situations.
Yeah, Im waiting whilst the guy that does my electronics finishes doing what hes doing so he can carry on with the PIC programing. Should be a month or so before we can get that sorted. In the meantime, im desperatly trying to work out how to get my servo to move the standard lens the whole way. becasue a servo only rotates 180 degrees max, so your average lens that moves 200+ degrees is often too long for the servo to move. i can move my Canon FD 28mm all the way with my servo system, but I cant move my 50mm anything more than 140 degrees, so I suspect the average lens would have to move too far for my servo to move. I am using the SGpro lens gears which are 126 teeth. You could extend the range of movement by using a lens gear with less teeth. Maybe the redrock...
