Relinking audio to video
jumpthewire
if you insert your video only into your sequence, is there a way to go back
and tell FCP that you want the audio as well?
After you did a cut with video only?
hope that makes sense
shawn
You got it...Easy way is to stick the play head overtop of the clip, click F (match frame) and then click f10 (overwrite edit). Your in and outs usually stay the same, unless you have manually changed them.
J
