SomewhereinLA
I am looking into buying an M2 but I would like to fully understand the workflow. You put the M2 onto the HVX, add let say, a Nikon lens then what? How do you set your camera built in lens. Which lens do you adjust the focus/iris on. Do you leave the Iris of the built in lens fully open, where do you set the focus on? When you add a lens do you use prime lens or can you use zoom lenses as well?
Also does anyone use the M2 Follow Focus? does it work with the HVX built in lens .
Is the support plate/rods high quality?
How about the Achromatic lens? Do you guys use it much?
Cheers.
:dankk2:
Cheers.
:dankk2:
