stuckfootage
The idea is a 3-way color key: I plan to set up three light groups
on a dancer in front of a black background. Using normal indoor 3.2K lights
and primary filters balanced for approximately equal b&w exposure,
I hope to be able to shoot in color and then produce three different versions
in black & white, using each of the three channels.
Hopefully I can then do additive comping thanks to the black background.
So by selecting which channel (r,g, or b), to use at any given edit time,
I'll be able to choose one of three different lighting setups, and
still be able to layer images. Does that make sense?
I'm wondering...how should I plan this? Do you have any suggestions
for Roscoe or Lee filters?
I know that luminosity equals .3R + .59G + .11B, so should I
look for a filter transmission ratio that is the inverse?
In other words R= 3.33, G= 1.7, B= 9; scale it by a factor
of 10 and you get R=33%, G=17%, B=90%
So maybe I should use a Roscoe 4660 red with a transmission of 39%
a Roscoe 4490 green with a transmission of 18%, and a Roscoe
No Color Blue 60 with a transmission of 62% (not quite bright enough)?
Is this the right math to get the filters in the ballpark,
assuming I'm using identical lights at the same distance?
Obviously, I will check the exposure and relative intensity after
everything is set up, but I'm trying to plan what filters to bring, etc.
Thanks for taking a moment to try to understand my idea.
Your suggestions are most welcome.
Les
Les
