headache62
Hello fellow filmmakers!
I am having a bit of a problem, and I'm not sure what to do about it. Some background:
I have a Canon 60D and I shoot mostly using Technicolor Cinestyle (which is great, in my opinion). I edit mostly using Premiere Pro CS5.5 with a dash of After Effects. However, I just upgraded to CS6, and while I can open up my CS5.5 projects in CS6, I get an error that the LUT could not be found.
I'm using a Mac (late 2011 model) with 16 gig ram running OSX 10.8 (Mountain Lion). I tried re-downloading the LUT Buddy installer from Red Giant and running it again because I know that you have to install LUT Buddy for CS5.5 you have to install it for "CS5" and move it into the correct folder for CS5.5, and I figure that I'll do that again for CS6. So I run the LUT Buddy installer, and get the message that the Install is successful. Great. However...
I open up my Library and go to move the folders around (http://www.redgiantsoftware.com/support/faq/product-specific/composite-wizard/225/ - instructions). I go to Library/Application Support/Adobe/Common - but there is no "Plug-ins" folder there at all. No Plug-ins, no CS5 (or CS5.5 or CS6), no MediaCore.
I just tried opening up Premiere Pro CS5.5 again, and the LUT Buddy plug-in is not in the Effects menu where it previously was. I'm more than a little confused, and if anyone has any advice I would greatly appreciate the help!
