Recording Voiceover
hanguolaohu
Hi,
I’ve been recording voiceover using my powerbook G4, FCP HD voiceover tool, Griffin imic adapter connected to a consumer Sony ECM-MS907 mic. I use the FCP voiceover tool as it is more convenient for time slot recording while watching the video compared to Garageband, etc. Unfortunately, my levels seem very low and my voice sounds faint even if I speak loud. I am somewhat tech savvy, but am wondering whether I need a preamp for my mic to boost the levels? The Sony mic has a built-in AA battery inside and when I record to my minidisc recorder the levels seem fine. Is this because the minidisc has a preamp built-in specifically for consumer mics? I also have a Sennheiser ME66/K6 that I could use which is also battery powered. If I need any more equipment, any specific recommendations or setups would be most appreciated.
Thanks,
Alexander
The griffin imic adapter does not amplify the signal. You need something called an audio interface. M-audio makes them as well as many others. I have had the same problems as you with very low audio levels. It is just the fact that you need to amplify the signal some way for it to really be heard.
