I'm recording and providing sound for a small concert in a couple weeks. I have a PA system that has 6 input and 4 output sources from the PA. I will be running a CD with music through the system along with one vocal mic and mixing the two using the EQ on the PA system.
The main output are the speaker output, a main input/output for connecting another amplifier to the PA system, a monitor output, and RCA record output. This is my first time trying to record out of the PA system into my DVX100. According to my PA manual, the Main line out is post EQ, my monitor out is Pre-EQ and my Record out is also post EQ. I would prefer to record from the Main line out instead of the RCA record output if possible, the connection is easier because I don't have to deal with RCA to XLR connection
I tested inputing an audio signal from the Main out line directly into the DVX and it worked fine, but even though the PA manual says that the audio signal from the Main out line is at line level not speaker level, I found that the audio level into the DVX was still bouncing in the red zone. If I reduce the L and R audio input, then I can balance the audio signal coming in better but I lose all audio in my headphone even if I increase the headphone audio to it's maximum.
The audio section in the DVX manual is rather short and I'm wondering if there is a way to better control the volume of the audio into the DVX and control the headphone level.
Maybe there is better way to do this. Appreciate any help you can provide.
