africanmarty
hi guys i will be filming a mates band soon and will getting audio from the mixer and filming with my AF100. i'm not sure if the output from the mixer will be RCA,3.5mm jack or XLR ( do mixers often output as XLR ?? ) my understanding is if you are recording audio from a mic then switch the audio option on the cam to 'mic' and if you are recording from a deck or mixer switch the audio option in the camera to "line" is this correct ??
now it doesnt matter what type of cable the mixer will output as i have a ''SM Pro Audio - M patch 2' wich will accept 3.5mm,RCA x2,XLR x2 inputs and output to XLRx2 so i'm not worried there. but since i am using the SM Pro Audio - M patch 2 and oututting to XLR x2 and into the camera should i choose 'line' or 'mic' ??? as its not directly coming out of the mixer/desk now.
PS: the reason i am using the 'SM Pro Audio - M patch 2' is so i can be safe and take almost any audio connection (3.5mm,RCA x2,XLR x2) attenuate it and output it to the AF100's XLR inputs.
Hope i made sence regards Marty.
here are some pics of the SM Pro Audio - M patch 2 :
Front:
Back:
Front:
Back:
