j1clark@ucsd.edu
I'm really confused now. When RECORDING, there is no reason to not record whispers loud, peaking at the same levels as when you record the actors shouting - you are attempting to capture maximum dynamic range not reality! A recording using the full available dynamic range without ever hitting the full scale digital maximum is as good as it can be, quality wise. Common sense means that it's usually a bit less - but you are not attempting to balance out in the field, just capture. Back in the studio or in the edit, you balance the shout against the whisper - and dropping level is so much better than trying to raise it when the levels were poorly controlled when it was recording. Many people under record, level wise and spend time normalising in the edit - but sometimes this really brings up the noise floor!
Here's where I think the use of 'noise floor' is misleading, given that it appears that audio people use different terms for 'noise floor'...
So perhaps 'room tone' is a better word to describe the 'nose', from which any 'signal' is measured, at least in the capture of production sound. The contribution to this maximum level of 'noise' by 'electronics' is down in the -90 or -100 dB level, way below 'room tone', and only 'hearable' by someone wearing headphones in an audiologist's sound booth.
"Room tone" seems to also be divided up into 'things that are not distinctly heard'... so the traffic from a street via a window is a 'room tone contributor', but the 'chain saw massacre' in the next room is 'ambiance'...
In any case it is clear that 'adding gain' will raise the level of all noise contributors, whatever the source, along with the desired 'audio signal', the dialog.
However, for some set of 'noise' contributors, filters can attenuate the 'noise', leaving the desired signal less attenuated and thereby 'stronger' relative to the now filtered out 'noise', effectively raising the SNR.
