Reconnecting Subclips Media
moonunit
Some of my media disconnected when I, like a big dummy, changed the location of the files. I was able to reconnect the raw footage but the subclips will not reconnect. I googled this and found a few answers that say the subclips should automatically reconnect when the master clip is reconnected but this is not happening. Has anyone experienced this or know a solution?
Thank you!
They should. You mean the clips inside the actual Sequence, I assume.
What version of FCP?
Save, quit, relaunch the project, see if that helps.
If not, in the Timeline window, Cmd+A to Select All. Then reconnect from there. Some older versions of FCP needed this when you moved stuff to a new location.
