Recommended Tripod for DVX100b
pnugent
Any recommendations? Due to budgetary constraints, I can't spend more than $1,000. The Manfrotto 503 fluid head tripod seems to be mentioned alot. Any comments on this one? Others? Thanks, in advance.
pnugent was looking in the $1,000 range. Any recommendations for one substantially cheaper? I'm still broke from the camera :)
I don't have a definite price range, but I'm mainly doing non-motion interviews for documentaries. Looking for something simple, compatible, and easy to operate.
thanks!
MG
I love my libec ls55, $850 form texastapeworks, Great tripod, Blows my 503 right out of the water! I hear even the LS38 ($600) is quite amazing, They are built like tanks!
Jon
Libec H22
Libec H22
I have the Libec H22 fluid head, which is rated to 8.8 lbs and is a great match for the DVX100 if you're not using a lot of heavy lens adapters and matte boxes and such.
Definitely the Manfrotto 503HDV head with 2 Stage legs & 75mm Bowl. The Miller DS10 Head is also great but more expensive
Will the Manfrotto 503HDV with 3246 legs be able to support a DVX100b with rails, 35mm adapter, follow focus, matte box and monitor?
It says it has a 17.6 lb weight limit, but I'm not sure what all of the accessories add up to.
It will support it as that's pretty much what I've got going at the moment although the friction centering function doesn't work properly when at that much weight. As a fluid it head thou it still works really well.. I'm happy for the $
If your on a budget, perhaps buy a 501 manfrotto head seperately, new.
Then buy a secondhand large sturdy tripod and rip the head off and put the manfrotto on.
I just got the Libec LS38 because im hearing more and more great things about it
Hasn't arived yet but when i tried it in B & H it was glorious
nice sturdy build and very smooth
so i guess id recommend it but i havn't actually put it to the test
Alright so I am in desperate need of a tripod, I will only be filming snowboarding and my budget is around 300 give or take 50$. I will be using a dvx100b with a century optics mk2 death lens. Does anybody have any recommendations? I will need to order asap so any help would be muchly appreciated.
