Recommendations for Sound Booth?
Mark-P
We would like to purchase a few small pre-built booths for recording audio narration for a college. The audio will eventually be placed into the timeline of Final Cut or placed online. The booth needs to be large enough for a computer, mic, and any other necessary equipment. I did a search and found some, such as,
http://www.acousticbooth-studiobox.com/products_standard.php
Has anyone ever worked with anything like this before? Can anyone make any recommendations?
Thanks!!!!
I dont think you'd want the computer in the room since those tend to make noise with fans and such - if your computer happens to be silent, then i guess it's ok (or if it's in a hush box of some sort
Mark,
As Fiddler pointed out you don't want to put gear in the booth. Typically they will have, or you can easily install a patch panel to run lines for mics, monitoring, etc.
In my studio, I don't even have computers in control room, but rather have them located in an adjacent room to keep the noise down.
If you are willing to do the construction you might check out something like this
http://www.dawbox.com/DAWBOOTH.htm
Whisper room might be the most common pre-fab booths, but they are also very expensive.
