Cole
I will be capturing some dialog to be used as a voice over for a current project. I will be recording in my home theater which has carpet on the walls (bottom half) and a layered curtain style material (Top Half). I took too long deciding on a new Mic so I am going to use my Rode NTG-1 in a Rode Blimp w/wombat connected to my DVX (no pre/mix). I know it isn't ideal but I am going to run with it anyway. I plan to boom the mic aimed at the floor with the reader about 4 inches away and slightly below mic level. To cut down even further on any noise I will be building a makeshift sound booth with sound blankets, C-stands and some egg crate foam. Nothing permanent, just clipping it together for the voice over. Here is what I'd like to know:
1. Due to the pick up pattern of the shotgun (small tail behind), does it hurt, help or not matter to have a sound blanket directly above the mic (touching)?
2. Is it necessary to have a blanket up behind him? As it is now both of his sides have a blanket as well as above him, a carpeted wall is about 3 feet behind his chair and there is carpet where the mic is aimed.
3. In a controlled environment like this, would I have noticed a difference with a mixer sending in a line level signal?
4. Since there is no wind, is the wombat and/or the blimp overkill? The other options being a bare mic or the included foam that came with it.
Thanks in advance for your input.
Cole
Cole
