So I'm in the early stages of pre-production on a new short. The Director wants to build a set and then use rear projection, or alternatively a large flat as a background to the set.
I'm pretty confident that this will work, but I've never worked with rear projection before and I'm interested to see if anyone on here has experience with the format and can shed some light on the best ways of working with it, and also the pros/cons of using rear projection over a flat. I assume one would need to use an HD projector, and obviously match shutter speeds etc.
