evilken
I just got hold of a pair of M-audio BX5s and plan to hook them up to my macbook pro for simple audio work. The main idea was that I'd have a reasonable idea what the audio sounds like in FCP so I can make basic offline cuts - I would always use a sound designer for the final mix so I don't need my setup to be anything more than basic.
My main question is, what is the simplest way to hook them up to the computer!
The BX5s are powered near field monitors - each has its own power supply. The only inputs they have are an XLR and a 1/4" TRS.
I'm guessing I need a splitter coming out of the headphone jack of the computer? Then a TRS lead going to the left speaker and a TRS to the right? My only worry here is, will I be sending two stereo signals out of the splitter - as opposed to a left and right signal?
I'm trying to avoid buying a mixer as the budget is spent already....
I do have an Arcam black box DAC lying around at home, so would it be an idea to instead use this as a passthru, using the macbook digital audio out. OR would this make little difference?
