Re: Sony Vegas Pro Question???
tracks83
@ questions regarding Vegas Pro.
1) I currently downloaded the Pro trial version. I ran into a problem with my PC and it looks like I'm going to have to restore the system from scratch. Would I be to donwload the trial again and continue working with the remainder of days I have left? or Once I restore I will not be able to work with the tiral version.
2) So far I've been working on the trial version and I have to say I'm sold. I will buy the program at the end of the month. I have two PC's that I work with but one I want to dedicate just for editing. Can I load both Pc's with the software or am I limited to one machine? If I am limited to one machine and the system fails and I have to do a complete restore will I be able to pop in the disk and reload it?
I'm asking b/c I now certain programs only allow you to download to one machine unless you pay for the licensing fees.
Any input would be greatly appreciated
1) Most likely. When you reinstall Windows, it'll wipe everything clean, including the record of your trial.
3) You get three full licenses with your purchase.
From Sony Knowledgebase:
Running Sony Media Software programs on more than one machine.
Question
Can I run my Sony Media Software application on more than one PC?
Answer
Our licensing agreement permits you to install the software on as many machines as you own, as long as you are not running the programs at the same time. For instance, you can install the software on your home machine and on your laptop. You are not allowed to install the software on multiple machines if you are going to be using them simultaneously, such as in a home studio setting. If you are going to run the software concurrently on more than one machine, you would need to purchase a separate license for each computer.
Note that when you install the software on a different computer you will need to complete the registration process again. Register the software as you did the first time to unlock the program on each machine. You can register online directly within the software, via the phone, or on our website through our online form.
I think rather than "three full licenses" there is actually one full license with the conditions stated above, plus 2 render-only licenses for network rendering purposes.
