ectobuilder
Re: Footage/Asset Management - Advantage to FCPX????
With Libraries, is it fair to say that FCPX has an advantage over Premiere Pro?
In FCPX, is it true to say that footage only has to be imported once into FCPX and can be reused over different projects whereas in Premiere Pro you'll run into situations where you'll need to import the same footage more than once (if different projects reuse the same footage such as if you are putting together a demo reel to showcase your work for the year?).
