Re: After Effects // Rotobrush
How do I use rotobrush to separate the talent and the background so I can adjust the color separately for both?
Currently I can only do the talent or the background but not both.
What I've read and what I've also used is advance frame by frame. You're already in the Paint window, right? You ought to be that and FULL Res. there is a little <<<||>>> looking bar in the Paint window timeline. You can grab the >> or the << and drag it to whatever time you'll want to process, for instance you're in the middle of the <<||>> area and you want to drag it 20 seconds to the right or future. Just grab the >> area and drag it to the 20 seconds advance.
When using the roto brush it is really important to get a good base to start. so plan on zooming in, even to pixel level if needed to give a good base reference for the program. Then advance frame by frame to ensure the lines stay where you intended. Adjust lines as necessary.
HTH
