Raylight setting?
New_Zealand
I have uploaded Raylight Ultra. Not really sure what setting I should have so I'm checking with you guys to see what you use. I'm editing on Windows 7. Feature film shot on 720/24pn. This is the setting I have set it at. Sorry it is soooo burryyyy Thanks
Your settings all look good to me.
Two other things I would suggest in addition:
1) Turn on "Mark Red/Yellow/Green" which will give you a visual indicator if for any strange reason you accidentally get Raylight set to any of those outdated, un-needed modes when rendering your final output. It can't hurt.
2) If you are using Vegas 7 or 8, turn on "Suppress Recomp" which will in some case prevent re-compression if you render out to a Raylight AVI. It doesn't work in Vegas 9, but no matter what version you are running, it can't hurt.
