Cees Mutsaers
Does this programm besides native use of MXF files in FCS also an improvement of the image quality since the native MXF files are used?
No it's the same quality as using Log and Transfer files.
To clarify, with P2 files and FCP 7, Log and Transfer re-wraps the MXF files in quicktime format without recompression. Raylight does not re-wrap the files, but it creates link files which point to the original data in the MXF file, which is a much quicker process. In both cases you end up editing with non-recompressed video, the quality is the same.
The advantages to Raylight for Mac are 1) no waiting for Log & Transfer, 2) no drive space needed for Log and Transfer files, 3) Clips can be named and grouped by Metadata and 4) Metadata in the bin.
Thanks for your explanation. Ok you are an expert so I have another question. If I duiring a shoot from clip to clip change the parameters within "one" schenfile setting, can I trace back all the settings of the scenefile of each induvidual clip or do I have to write each change down on paper for each clip?
Another question I have is if it is possible in FCS to export a finished project in something other than a mov-file ??
